V-Ray 6 f. Sketchup verfügbar - Druckversion
+--- Thema: V-Ray 6 f. Sketchup verfügbar (/Thread-V-Ray-6-f-Sketchup-verf%C3%BCgbar)
V-Ray 6 f. Sketchup verfügbar - POSH - 07.10.2022
What's new
Next level collaboration
V-Ray & Enscape compatibility
Introducing the most powerful visualization workflow in the AEC industry. With V-Ray 6, it’s simple to transfer real-time scenes from Enscape and continue building on work to take it to the highest possible level of photorealism.
With support for Enscape materials, 3D models, and lights, V-Ray ensures that all design decisions are kept throughout the project development stages and collaboration between designers and visualization specialists is smoother than ever.
No dead ends. No starting over. A seamless end-to-end design process.
Chaos Cloud Collaboration
It’s easy to share work and collaborate with internal and external stakeholders on the cloud. With Chaos Cloud Collaboration you can upload your images and image panoramas straight from the V-Ray Frame Buffer and significantly speed up the approval process.
Streamline your workflow
Procedural clouds
Add just the right clouds for any scene without spending hours browsing through HDRI libraries. The new procedural cloud system is a flexible and memory-efficient way to create any cloudy sky and animate it for impressive timelapse presentations.
V-Ray Enmesh
Create complex geometric patterns over object surfaces to make panels, fences, fabrics, and more in an automated and memory-efficient way.
Finite Dome light
Fine-tune the scale and add depth to project environments when using image-based lighting with this new V-Ray Dome Light mode.
Enhanced Material Creation
Distance Texture
Vary effects such as displacement or procedural fur based on proximity to create a realistic correlation between the elements in a composition. Create a well-trodden path through a procedural lawn or form dark spots under downspouts.
Enhanced Dirt texture
Place dirt with higher precision by adding or excluding objects.
Better translucent materials
Render translucent materials such as frosted glass or marble faster with the V-Ray Material’s improved subsurface scattering mode.
Iridescent materials
Easily create iridescent materials such as soap bubbles, oil spills, and more with the new Thin Film option available in the V-Ray Material.
More accurate reflections
Metals and rough reflective materials render more accurately thanks to a new energy preservation technique.
Other
Pause your renders
Pause and resume renders at any time.
Asset tags
Group assets using the new tags system in the Asset Editor to improve scene organization in complex projects.
All assets inside Chaos Cosmos
V-Ray’s built-in material library is now part of Chaos Cosmos, so it’s easy to find and manage all assets in a single location.
ACEScg Color Management
Take advantage of a wider color palette for render output with the industry-standard ACEScg color encoding system.
Smarter light calculation in interactive mode
Achieve better-exposed results that are even closer to final render quality thanks to Light Cache calculations in IPR mode.
Shop
Info
Demo
